Hi Jon . Yes they all have an oil temperature sensor . Our Mini still has it but I replaced the dial for a pressure gauge some years ago now as I prefer to see pressure rather than temperature. The car now gives a fault code for open circuit for this but I just ignore it." Do all MPI Minis have an oil temperature sensor? "
well mine does , as seen in the log files , its a 1999 MPI mini so I'd guess they all do.
This is great news that the stepper feature has arrived.
My TF Sunstorm 115 has always had an intermittent weird throttle issue. Changing the idle value helped a bit but it only ever ran well just after Russell Walsh changed a piston liner and got him going when I first bought him as a scrapper!
It's laid up on the drive at the moment unstarted for months. I'm going to fire it up today and give the new feature a go if I can, and I'll report back later.
Sent from my VOG-L29 using Tapatalk
Will do. Just realised the stepper is only for Mems2 not 3 like mine? Just charging the battery before starting.
Please can you check that pscan works with all the other ECUs on your TF as well?
042A has a lot of code changed under the hood and so I have retested every ECU that I have, but I don't have an MGF EPAS ECU.
