I have recently bought an MG TF 03 as a bit of a project and with the help of my neighbour (who knows what he is doing) we have done a lot of work on the front of the car - sub-frame mounts, wishbones, ball joints, TREs, discs and pads.
The final thing we needed to do was the rear sub-frame mounts. The first of the mounting bolts sheared off. Ludicrous design and size of bolt for the job. After much swearing and scratching of heads we packed up for the day.
I have read the excellent how to guide on what to do next with drilling out, re-tapping and a helicoil kit. I have a couple of questions:
1) The guide makes it sound really easy. My gut feeling says it isn't! If anybody has done this, please can you advise how difficult it was and how long it takes? What size drill bit did you use. I am thinking using left handed drill bits - initially a 4mm and stepping up to a 6mm and then 8mm if necessary. Optimistically hoping a left handed thread might pull the bolt out
2) How on earth do I get the other 3 bolts out without the same thing happening? We gave it a spray, a bit of tapping with a hammer and heated with a blowlamp. Any other advice?
3) Has anyone put the main sub-frame bolts in the opposite way round (i.e. nut inside the mount cup) so that you don't have to drop the sub-frame? This looks like it will work although pretty tight to get a socket on the nut to stop it from spinning when torquing up. I have replacement bolts so can angle grind the originals out. Anyone any experience of this?
Many thanks in advance...
