Rich,
I run 195's on the front and no rubbing issues, also my car is on pins and lowered (320mm f, 315mm r) the camber is notiable when you look at the car from the front but I all I have done it just the 4 wheel tracking. I made a decision that Tyres were cheaper than the Camber adjusters.
T
it my not be the head gasket,sometime the liners need reseating,but its a head off job.we can do mot work,and we have a few second hand exhaust systems and cat from when customer fit new sports systems.and we have a loan metro gti customers can take and i charge £35 per hour,
Thanks gents! That is exactly what I needed to know, and thanks Ozzy for those measurements. I have been wondering what the toe-in/out should be on a lowered car. I will run with the previous settings for now as I will be changing the displacers in a month or so and don't want to do the alignment twice. I'm sure I could have it done now, but probably best to wait till things are fully sorted.
Rich,
T
i used the gammon and brown lowering knuckles, and Gaz adjustable dampers...
sent the car to Back on Track in guildford to do a full Geo back to as close to a fast road/light track geo as we could get...
i think the settings they settled on was something like 2mm toe in front, 1.5mm toe in rear, cant adjust camber, but they said it shouldnt rub, and certainly i have never felt it rub... (this could ofcourse be wrong as i cant remember for sure)
interestingly someone else on SELOC said they had seen similar side split on a very used set of R1-Rs from excessive track use... so could just be the construction of the tyre and the way it degrades... i was well below the wear markers, on the middle-inside of the tyre, even though the outside was above the wear markers...
Oz.
If you wouldn't mind double-checking those figures Oz, I would appreciate it!
