Uncouple the fuel feed pipe connector at the inlet manifold, put the uncoupled end into a clean jar/bottle, ignition on and crank the engine, the electric fuel pump (which is inside the fuel tank) should for a couple of seconds when you switch on the ignition then stop, then run again when you crank the engine with the starter or when the engine is running (+500rpm)
If you have a spark and the fuel pump is running when cranking then there is no immobiliser issue, however as the above posts check the fuel quality, if you suspect the fuel to be stale then bridge the fuel pump relay and empty the tank at the fuel line coupling as above, you can put a piece of garden hose over the coupling and tape it up, and the other end into a drum. In one minute the fuel pump will move about 5 litres, so it won't take long to empty even if the tank is quite full.
You would need to put at least 10 litres of fresh fuel back into the tank to dilute an stale residue left behind.
With a spark and fresh fuel she should run, it would be very unlikely to be timing related if the car has just been stood, if she still won't start the next thing I would try is a compression test (for a petrol engine to start you need over 80psi) If the compression is low it could be because car has been stood for a long period and some valve seats may have surface rust, this may be where you will lose compression. If this is the case remove the plugs and put 5mls of engine oil into each cylinder, still with the plugs out crank the engine for 10 seconds or so, this will put a coating of oil on the valve seats and help raise the compression, re-fit the plugs and give it a try. Once the engine has started let it tick over and warm up, this will clean the valve seats.
If you get her running after being stood for 8 years the next job is a new timing belt. Do this before you give her any high revs or the put the engine under load, the belt will be deformed with being sat in the same position for such a long time. Same goes for the tyres unless she has been on blocks.
