If you have it pumped up to 400psi with hydrolastic fluid if it is standard it should measure arround the 368mm mark, I don't know of any way to check for lowering pins, but I do know 400 psi is the operating pressure and mine is 360mm at that pressure.Thanks Mark, that seems quite a high failure rate for the spheres you've replaced. I'm hoping mine are OK, I haven't seen any fluid leaks, and there is some movement at least at each corner of the car.
When you re-gas spheres how do you get the right amount of gas in ? Do you gas them up to a given pressure before putting any fluid at all into the lower chamber... I'm just wondering if I sent my units away to have valves installed how I would get the suspension properly set up when it was re-assembled. It seems to me that it might be possible to end up with, say, more gas and less fluid in the front, and more fluid and less gas in the rear, and with the two units interconnected you'd still get a similar amount of static springiness at each end, but the response over real bumps when the car was moving could be quite different ? Having said that it does seem as though my car has probably not had too much fluid added as yet, so maybe I should just go for a conventional fluid pump up and see how it feels.
I guess it should be possible to measure the distance from the bottom of the cone to the top of the suspension arm to know whether I've got standard or lowering knuckles, but I don't know what either measurement would be.
