I have used soapy water to clean the hood and then sealed with fabsil, there are other products specifically for soft hoods that I have tried but none have been better than soapy water and fabsil in my opinion others may disagree, as far as the door, the hinge pin has been known to wear alowing the door to drop so check that first, hold the door and lift up, if it's worn there will be significant movement upwards, all fixable without a new door.Hi I am new to the forum and would like to know what's the best thing to clean the hood with and what to use to give it a water proofing treatment?Also my drivers side carpet is beyond saving so my question is are all MGF items interchangeable?Will a mk1 carpet fit a mk2, is an item from an auto the same as a manual car?I have also noticed my drivers door has been fitted badly it's tight where it meets the rear wing with a big gap by front wing.The top of the door with the weather seal is proud where it meets the body and the lines do not meet up.Is it best for a 2nd hand door or try shimming the one I have?
At present the MG is covered up in the garage while I paint the walls and looking forward to the nice weather.
Any information is much appreciated.
Thanks
Tony
