I have also started to do this. The new hub gives you a new upper ball joint too, so you do two jobs in one, also it forces you to remove the abs sensor (if fitted) and the 9 times out of 10 seized bolt that holds it on and replace it for a new stainless one that wont weld itself to the hub casting! Oh and while you are at it why not clean the brakes up while they are off.....new drop links are a must too! you can get carried away, but once the hubs off, it does give you chances to replace a lot of wearing parts if you wish....mmmmm shiny new grooved EBC discs to go on the new hub .........Replaced the whole hub part with a new one.... SO much better now!
Sundance
