I have had my steering wheel off about three times over the last year, and gave it a good thirty mins of discharge time, it was ok and no airbag accidents, but if you do take the airbag off, handle carefully and do not put it down upside down, cos if it went off, it would be fly!MGs official line was disconnect the battery for 10 minutes before touching the SRS system, personally I just never touch the airbags unless the ignition has been off for several hours.
It wont be the alternator.
It could be a failing relay in the BCU.
.......The advice I was given was to keep the horn pressed and it will probably come back...
