As some will know... I have sound proofed every panel on my F with 2 mm bitumen sheets
This was heated up with a paint stripper gun and then bonded onto panels in an attempt to deaden the sound
I've done the entire floor, inside the fuel tank area, fuel tank cover panel, every surface inside the cabin, inside wings, doors, boot etc... Entire engine bay
Some areas then have 10mm closed cell foam applied on top.. Front and rear wings have 10mm foam applied
The reason for the sound proofing is I want my car to be quieter on long journeys (euro trips) but also to improve the sound for the new sound system going in..
Was chatting to a guy at the weekend who used to build 'sound off cars'... He reckons I should spray expanding foam into any remaining cavity..
There are loads of cavities.. Sills, rear wings, in the cabin, in boot lid and under side of bonnet..screen surround etc
Anyone done this? All that worries me is expanding foam burns, so if ever I need to do any welding I'm stuffed..
The sills have already had waxoil pumped into them, so as long as i sprayed inside the other cavities first rot shouldn't be an issue
If you tap my panels now they sound like concrete... So happy so far with the results... But expanding foam? Any views?
