MG T-Bar Quiz
Can see where you're coming from smithp25, there is some resemblance in the two towers...
... but I don't think it is
No. It's Northern England.
Maggy( Birks) organised the run, if that helps?
- a Guest
- User
Nope, quite near Cltheroe.
Apparently Tolkien wrote part of Lord of the Rings here.
- a Guest
- User
- a Guest
- User
:woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
Well done SS, now stop all that dancing and set a question
That moves you up to 3 slices of pie, equal with bensewell and Whiz
Last Edit:13 years 8 months ago
- a Guest
- User
When fitting lowering pins to an MGF and a MGTF what are the recommended heights for each car
- Mr Forgetful
I have no idea what you do to a TF as I thought (I am very ignorent on cars - computers are fine though) that you only fitted them to F 's?
Anyway fit and pump up the hydragas to a height of 340mm (courtesy of MGF register).
Back to the paper
Back to the paper
by Mr Forgetful
- a Guest
- User
No TF's can have them as well
and I am not on about the height when using hydragas as TF's do not have it :slapme:
I'd say 350mm you can fit 2 fingers between wheel and arch then
But.... Ultimate MG say 330mm
http://www.mgf.ultimatemg.com/group2/diy/suspension/howto_lower.htm
by bensewell
Time to create page: 0.544 seconds
