Can pscan enable the factory low coolant light
Can pscan enable the factory low coolant light was created by MarkTF
Posted 4 months 3 weeks ago #221971Any help appreciated.
Replied by Cobber on topic Can pscan enable the factory low coolant light
Posted 4 months 3 weeks ago #221972It may well be that such a box may need to be fitted to your car.
Hopefully someone more familiar with the TF will be along soon to enlighten us further on this matter.
Replied by Delbourt on topic Can pscan enable the factory low coolant light
Posted 4 months 3 weeks ago #221974I have Dec 2004 built MGTF 135. When I bought it that light was permanently on.
I checked the wiring and it wasn’t plugged in . After plugging it in at the base of the tank the light went out without any intervention from Pscan.
Replied by MarkTF on topic Can pscan enable the factory low coolant light
Posted 4 months 3 weeks ago #221981Thanks
Mark
Replied by Notanumber on topic Can pscan enable the factory low coolant light
Posted 4 months 3 weeks ago #2219822003 MG TF 135 sunstorm
Replied by Roverlike on topic Can pscan enable the factory low coolant light
Posted 4 months 3 weeks ago #221986I have bought a new coolant tank and low coolant sensor. My car is a 2005 TF 160. The plug already existed for the sensor and has 12.5 volts running through it, as tested with a multimeter. The problem is that the light will not come on when the tank is empty and ignition is on. According to the manual it should light for 4 seconds and then extinguish. Given it stays on for 4 seconds I would think that the ecu controls this. I have checked the bulb in the instrument panel is there and works and it also looks like the wiring is there too. So, I am wondering if it has to be enabled when a factory sensor is fitted and can pscan do this somehow.
I do wonder why you measure 12,5 Volt on plug because there should be none.
Are you sure you have correct plug in hand?
- BruceTF135
Replied by BruceTF135 on topic Can pscan enable the factory low coolant light
Posted 4 months 3 weeks ago #221987Way back in the mists of time, when I first trialled my coolant alarms on a few T-Bar volunteers, I was contacted by a chap called Bob; his T-Bar username was Bob Essex. I don't know if he is still a member here.
His car was a 2005 TF. He took one of my coolant alarms before discovering the same wiring around the coolant tank. He also bought a coolant tank with the internal sensor, thinking that just connecting it would be all that was required. It didn't work and, because he was local, I had a look at it with him. It didn't help, so we fitted the low coolant alarm I had supplied to him.
There is a thread here .
Somebody must know what the secret is. Could it be that we have reached the limit of Roverlike's knowledge?
Posted 4 months 3 weeks ago #2219882003 MG TF 135 sunstorm
Posted 4 months 3 weeks ago #221991I probably should have got involved in this a bit sooner because I have come across the problem Mark describes before.
Somebody must know what the secret is. Could it be that we have reached the limit of Roverlike's knowledge?![]()
Low coolant alarm is operated by Pektron SCU unit. So if it is not working it needs to be enabled within SCU. SCU is responsible for bulb on dash for low coolant alarm glowing few seconds on ignition startup.
Posted 4 months 3 weeks ago #222013Please Log in or Create an account to join the conversation.
Posted 4 months 3 weeks ago #222014Why should there be none?
Because low coolant switch is making connection to earth. That would mean if switch is connected we would made short circuit and something would be burnt.
One wire is connection to SCU/BCU other wire is Black earth wire. Switch is making connection of the two wires and thus providing earth connection to SCU/BCU of designated pin and by that providing info that coolant is low.
- BruceTF135
Posted 4 months 3 weeks ago #222016Please Log in or Create an account to join the conversation.
