Hello,
Not my first post due to a rust based panic!
But I thought I'd say hello and show you all my MG.
It was fairly well cared for by its previous owner, just not the ones before that! Hence the rust issues!
Few issues I want to sort out though and would like some advice:
It has a massive K&N cone fitted, which is filthy and sucks in nothing but warm air, now i dont know if i should clean it and fit ducting or fit an airbox and performance panel
The exhaust is blowing, I think its at the backbox flange as this is covered in gungum and the mounting strap has fallen off? the backbox itself is rusty as anything so I will be replacing this with a MGOC supersport soon, is there any cheaper alternitives and does anyone know where i can get a mounting strap cheap?
The engine clunks when I pull away, I think its probably some sort of torque control bush, is there a common one that fails?
Best coolant level switch? my mum spent my childhood cooking k-series engines so I have "the fear"
The brakes are awful, spongey and terrible bite. The front discs and pads are fairly new so im unsure theyve been bedded in properly as the fluid is fine?
I think that's it for now, im currently abit skint so cheaper options are preferred, aslong as they last as I want to keep this one for atleast two years!
Cheers
