If you want to run nitrous it will be pretty vital to stiffen up the crank and big ends and invest in forged pistons to avoid a very expensive first shot of nitrous, and a sump full of engine bits.
Where were you thinking of getting the head done?
Can point you in the right direction if you are intersted.
Chris
Very true its the differences which make life interestingAfter seeing it at last years Artic Circle run I really didn't like it. But that's just my opinion and this would be a pretty boring place if we all shared the same
http://www.ricwood.com/modern_race_engines.htmlYep, that's the plan along with the 1.9 or 2 litre conversion Going to really go all out and build it up to handle as much as I can afford.
Not really thought about where yet, I reckon I probably have about a year or so before anything actually starts to happen so plenty of time to look into all the different options and compare them. A couple of first ideas are either Dave Andrews or Modus who are a local company. Any recommendations would be gratefully received
Yes really some makes have been dreadful shoddy, mismatched and just plain dangerous.The Gaz units are pretty good and not bad value for money, can be a pig to set up to get your clearances equal for each coilover, a fraction of a turn on the spring seat different to to opposite corner can put the corner weights out by as much as 10% so very much need to set aside a full day for fitting and setup.
The MS kits are very good and use the same Spax dampers that I have which are great, the springs he uses are very good to but drop the car more then his figures suggest. A TF with the red spring kit will not clear even the tamest speed bump without grounding the floor pan- really a track spring.
Chris
Wow, I've not seen it in action before. Very impressive! How do you think it affects the car?In all honesty I dont really know...
But I'd bet good money I've forgot loads more....lol
For those who haven't seen the first test of the active spoiler
I have four ways of controlling it
Manual, like a window up an down switch and it stays were you set it
or goes fully up under braking and returns when you come off the brake
left corner g-force which has a variable adjustment
right corner g-force which has a variable adjustment
when using manual control all others are disabled
when using auto mode, braking and cornering act together, so you brake for a corner it goes up and then the G-force switches keep it up after you come off the brake through the corner till you hit the striaght when it goes down again
