Err... one of my rear damper top mounts fractured. With standard dampers fitted...and no rust either.
i have seen these a few times.rover dampers cant damage the body work they simply are not strong enough,when people started fitting after market shocks we started seeing these happen,and it would happen a lot.The rear of the car is heavy and the mounts are weak.The hyro lastic pods took most of the stress and the damper took the damping power.
But with stiffer dampers the damper then took all the shock and the hydrolastic almost became redundant.
There where two makes that would do this damage spax and bilstene.they are simply too strong to work on these cars.
In fact within 10,000 miles the rear would be wreaked.The problem is now that the cars are old is the metal has got weaker due to age so the process is is sped up.
We have a number of photos of cars that we have put on here showing the damage.we only fit gaz shocks and these are on a setting that is safe for the car.Many cars suffer from these problem,hence the idea of welding plates on the mount.
We have removed more bilstene shocks then anything else and we simply bin them.We have also found that the bottom bolt can snap using these make as well.At one point rover issued a safety warning and the shock company did respond with a safety notice,but now rover has gone they just sell them.
I have seen myself around 40 cars over the years where the rear mount has failed or the bottom bolt has failed.
You have to understand how the suspension works.when the hydrolastic drops in height,the damper is pressing harder into the mount.and the car then can be found riding on the dampers rather then the pods,most cars have springs and these dont suddenly lose height.
Its not about track days or fast driving,its about haw the car is designed and how it works.
The same thing is one boy racers cars when the lower the springs and put stiffer shocks on,the car is no longer riding on the springs but the shocks.the a differant part of the suspension is doing a differant job.
The hydrolastic is designed to surport the wieght of the car and its contents.the damper thats out the bounce.
fit a stiffer damper and the hydro loses even a small amount of pressure,the damper is now holding up the car.and that is very dangerous,simply because the hydro is fitted to the subframe and the damper is attached to the wing.
bilstenes will go through your mounts regardless how you drive,unless you keep you pods inflated perfectly,and that will mean testing every month.
And to answer jans question about how many bilsteins have damged mgs.drive a car around with a almost solid bit of metal between our wheels and your bodywork instead of a normal damper and it wont take very long,one pot hole and it will be a rear wing damaged
