Having a MG-R Mk2 roll hoop kit fitted, the access to these screws are a bit fiddly for me, I only have one out of the three fitted to my cover under the t-bar, the central one.That's a great idea . I might be doing this as the threads under my T bar are getting a bit ropey .
John
I think the amount of decent protection most of the hoops offer is negligible, however the MG=Rover Mk.1 and 2 hoops are very substantial and bolt to the seatbelt anchorage points. The brackets are pretty solid and the bolts are M12 or M14 so pretty decent.On the subject of roll hoops are they all cosmetic or can you buy a reinforced t bar....never seen how roll hoops attach..but after removing the t bar for the first time..my thoughts are a piece of wood would be stronger has the t bar is made of tin...in other words roll hoops offer the same protection has a Cadbury crunchie....
or is there something else holding them on...I would feel better with all the pins originally intended to fasten the cover on in place..because after all that is a safety measure and has you know intended to keep nasty fumes from entering the cockpit....not seeing a t bar gives you the impression of a strong crossmember that you can bolt safety feature to....but in reality a badge bar for mounting badges on vintage cars would be harder to snap in half.
Ah seen these different types ..which one gives protection.
I think it's important to have fast access to the engine...not a big deal taking the engine cover off in your own garage and at your own leisure...but at the side of the road it not fun....anyone else got any quick access ideas....I did ponder on a idea of leaving the 3 pins under the t bar out all together and having a screw able clamp system..pressing down on the engine cover..but I think this would be better with a t bar made from box section..so the clamps./..miniture jacks have something to press on.
Got to get mg shopping list in order..
4...Honda engine
I think the amount of decent protection most of the hoops offer is negligible,On the subject of roll hoops are they all cosmetic or can you buy a reinforced t bar....
