The window, on the driver side of my Y reg MGF has gone out of alignment. It is stuck in the up position. When the down button is pressed it goes down about 5mm and stops. It is jamming against the sill at the lock side of the door. Does anyone have any ideas what I need to do to get into the mechanism and investigate re-aligning the window properly? I guess that I will have to remove the door panel first, and I am looking for advice on that too. Any suggestions would be gratefully received and humbly applied. Thanks folks.
