I know there are a number of threads on this subject, but this might be a different problem.
TF is a 115 that had a water leak from the manifold gasket and has been cured with an alloy one from a 135. Complete manifold was used with the blue injectors but the throttle valve ,IAC valve and wiring loom were swapped from the plastic.
Engine started easily and warmed up, after a few seconds it started hunting between 1000 and 1250 RPM when fully warm it still hunts.
Tried IAC valve reset no difference
Tried disconnecting IAC valve when running still hunts
I noted the the carbon filter is ticking??
Idle speed used to be 850RPM solid
Fluctuation is rythmic and not random
Any suggestions much appreciated
Edit
Battery had been disconnected for about three weeks
