Hi what have you took off ? Is there a how to to convert air filter to a cold air intake think it has got to be worth doing and it is going into be waxoyled any time now so would be a good time to get it done?
I took off my super sport s exhaust and sports cat and also K&N 57i Performance Induction Kit main reason really was to cut the cost of insurance by £150
The cold air conversion I have done was my own I don't know if anyone else has done anything like it before .... Basically I took the standard air filter box then removed the air intake pipe (held by 1 screw) then blanked the hole off. Then cut a new hole in the front of the box (side that faces towards front of car) at about the same level to refit the air intake pipe into (make sure its a tight fit or you will have to bond it in) .. fit the pipe so its pointing down. Then get some 60mm ducting (I use heart resistant aluminium off ebay) feed this from the intake pipe down to the nearside/leftside side body air vent .. you will need to fit this vent with a scoop as this will greatly improve air flow in ...thats it ....and unless you know MGF's it looks standard .... does it work? well I don't see why it shouldn't ... does it produce more power again I don't know but cold air is better than hot
I will try and post some pics later maybe do a how to post
