I had a similar experience which i solved by using the elastomer gasket!
I am not sure why it leaked but in retrospect i suspect one of the following (or both)
When I had the head skimmed (it needed doing as it had damage where the old gasket let go) the "specialist" who did this, left lots of small marks in the head caused by the "fly cutter". Large radius marks where each cut was taken. Resembled a very fine washboard. If you scratched the surface with a finger nail you could definitely feel a very fine ripple effect, every 0.5mm or so across the head.
This might be fine for a normal head gasket, but i feel a MLS would not seal against these.
Liner heights were checked and suitable for an MLS.
However if it is leaking water from the side i doubt liner heights would cause this issue!
The other concern was I bought a cheapo gasket from E-Bay
, and from what is said here in other posts this is definitely a NO-NO!
Replaced it with a Payen elastomer and fine ever since.
Once you have done the head gasket, the second time is easy
Peter
