Apart from it being in two parts it is very similar. The throttle body fits fine, and so do the injectors etc if you need to swap them over. The gaskets are standard flat type, one between the inlet and head, one between the two halves of the inlet. If you get a newer one you'll need to leave the big black MAF sensor on the drivers side even if you don't have it connected or it will leak air in, and there's an extra vacuum joint that side also you may also need to plug...
Mine was plastic leaky crap, went to alloy and never looked back on both my old F (had a VVC alloy inlet) and my 115TF (has a 135 alloy inlet).
Lower half:
Fitted:
