  • 2
Temperature issues/ speedo issues 9 years 9 months ago #147432
Hi guys
Just got myself a lovely mk1 MGF. But I have a few issues which I hope someone could help with.
1. Temperature guage not working- what do I need to check?
2. Pretty sure that ambient temp gauge also not working- how do I check?
3. Also speedo not working now and EPAS light on
HELP most gratefully received
Temperature issues/ speedo issues 9 years 9 months ago #147434
welcome quaswold,
1) check temp sender connection and resistance of sender itself in engine bay. someone will know there exact location and picture.
2) factory fit ambient temp was three lamps i believe not a gauge (anyone else on this?) most likely the sender under the front bumper being duff or connection faulty.
3) the mk1 had a multi section speedo cable, the rear part to the gearbox often fails first, if this happens, speedo fails then EPAS cannot receive a speed signal so cuts the system.
hope this helps as a starter for ten :)
The following user(s) said Thank You: quaswold
Last edit: Post by really?.
Temperature issues/ speedo issues 9 years 9 months ago #147435
Hi and welcome
Yeah, EPAS wont work if the speedo isn't.
I've never seen an ambient temp gauge, are you talking about the oil temp gauge on the left side of the clock?
James
Last edit: Post by talkingcars.
Temperature issues/ speedo issues 9 years 9 months ago #147439
Hi guys
Thanks for this information.
I will check all areas and report back.
really?
New speedo cable ordered of eBay (£30) not bad I thought
New coolant sender unit ordered(£10)
Will check under front bumper for sensor.
Talking cars
No definitely the temp guage in dash not working
Temperature issues/ speedo issues 9 years 9 months ago #147459
Sorry, I thought you ment ambiant air tempreture which means outside air tempreture.
Temperature issues/ speedo issues 9 years 9 months ago #147460
Hi, and welcome to the T Bar, I have the same issue with the speedo cable (the rear part). The cheapest I could find on flea bay was £40. Can you post the link to the company offering for £30 or was it a one off?
Cheers, Billy
Temperature issues/ speedo issues 9 years 9 months ago #147463
:welcome2:
Temperature issues/ speedo issues 9 years 9 months ago #147466
Hi billy
Yep it was a one off.... Pretty lucky really , all 3 parts and ends to boot
Temperature issues/ speedo issues 9 years 9 months ago #147470
It consists of 2 small rectangular LEDs (1 green,1 red) mounted in a small round holder, a ECU and a sensor.
The green light comes on above 5˚C for a few seconds when starting the car to show it's working.
When both lights come on the temp is between 5˚C and 2˚C.
When only the red light is on the temp is below 2˚C.
My car has it fitted (must be a pretty rare OEM accessory here in Oz)
Temperature issues/ speedo issues 9 years 9 months ago #147483
Must be pretty rare - full stop, mate. I've never come across an ambient temp system on them before. :nonod:
I agree that it would be much more useful over here than Oz. A photo would be good for future reference.:yesnod:
Temperature issues/ speedo issues 9 years 9 months ago #147484
Referring to the original question, the temp gauge(engine) is fed from a sensor on the engine coolant outlet pipe. Removing the plug and bridging the connections should give full scale detection. (ign on) This will identify if it's the sensor or gauge and wiring fault.
Temperature issues/ speedo issues 9 years 9 months ago #147485
I might take some happy snaps tomoz.
It's not as silly to have one here as you might think.
In the Sth East parts of the country in can get cold, maybe not what you lot would call cold, but quite cold enough, thanks!
In the states of Tasmania, Victoria, the southern parts of New South Wales and the Australian Capitol Territory it can often get to below 0˚C in winter, and to have a warning of icey conditions makes sense as most drivers here would have little experience of driving in such conditions so are probably more likely to get caught out.
  • 2
Time to create page: 0.110 seconds
