The MGF & MGTF subframes are bolted upwards into the floorpan & into enclosed box sections using thread-cutting bolts, great for ease & cost of factory assembly but not so great for the owner as the car gets older - they are very prone to rust, worsened by the fact they're thread-cutting type - the helix cut-out in the threads allows moisture to seep down the entire length of the thread, the resulting rust makes them progressively harder to remove and will eventually lead to them failing. Replace these with much stronger items (12.9 grade) with more durable anti-corrosion protection before the factory bolts degrade too badly and you'll avoid a potentially very large headache in the future. Bolts are supplied with stainless washers, set of 12 bolts does one subframe - 8 for rear mounts (replacing KYP10004), 4 for front mounts (replacing YYG10005A)
As an example, this significantly weakened bolt came out of a 2005 MGTF -
I am in the process of changing my front sub frame ATM but I was going to re fit the rubber mountshack slash
Learnings:
snip snip
Replace front mounts with Solid mounts on F, I used uprated ones from MGFandTFbitz.
snip
TB
