I've had a pig of a day changing my clutch cylinder seals.
Got everything off no problem (save for a stuck pin), seals changed easy enough, all back on the car no problem, bled the master all going to plan then came to bleed the slave and
First I just couldn't get anything out of the bleed screw so I disconnected the pipe and found I could pump fluid through so I thought it was a blocked nipple, took it out, nothing, it was completely clean. 30 minutes later took the cylinder back out and found the blockage was in the cylinder itself so cleared it and reassembled.
All now back on track and I pumped fluid through till the new stuff came through the nipple then tried pumping the peddle to get some pressure in but couldn't. Took the cylinder back out to check I hadn't blown the new seal, all fine and full of nice clean fluid but I still can't get any pressure, the peddle just flops to floor like it did previously.
Clutch release arm is stiff but moves, now coated in release fluid but surely I should be getting something from the peddle?
