Posted this on another forum and didnt really get to the bottom of it, anyone shed any light, maybe CJJ...? see you are in morpeth, me too.
Thanks
Paul
Ok, MG been running fine, (its' the girlfriends), head gasket done, reciepts etc.
Other day noticed the oil was low, so thought i would top it up, all i had was castrol magnatec so topped the oil up with that. Car is fine when going in a straight line, no problems, but when you start to go around a roundabout smoke bellows out of the exhausts. I followed her around the roundabout and it pours out, then when the car straightens up it stops...!!! so in a straight line its perfect...!!!
Anyone got any ideas ?
maybe a mix of synthetic and normal oil, as its been ok until i topped the oil up.
No oil in the water or vise versa, no signs of any external oil leaks anywhere etc, its just coming from the exhaust when going around corners...!!! it's definatley an inertia thing.
we found that we can only top the oil up to just over the minimum mark on the dipstick, anything over that and we get the problem.
