I've got a TF160 with 16" 11 spokes. The wheels are the same width all round but the tyres are different front and rear.Hi All, I'm wanting to upgrade the wheels on my TF115 to 16" eleven spoke as I'm wanting to do the big brake conversion eventually. The wheels I have are wider on the back than the on the front, Can someone tell me is the 16" wheel setup the same?
The 16" wheels also have lower profile tyres so the rolling diameter of the tyre will be the same. On mine it's 195/45 R16 on the front and 215/40 R16 on the back.Also is there anything else to consider like speedo calibration?
Your existing 15" wheels are the same width the rear tyres are wider that the fronts 185/55 R 15 front and 205/50 R 15 rears, the profile reduces as the width increases to maintain the same overall diameter (rolling radius) so the gearing is not affected. if you have a steel spare wheel it is a 14" wheel with a narrower higher profile tyre 175/65 R 14 .
