Hi is there a easy way of testing the thermostat as i think it is a bit of a job to remove and test in hot water. If it was not opening at all would you still get hot air from heater.Thanks.
the heater is on a seperate system from the thermostat
the thermostat allows heated water to the radiator
as for changing / testing iv got so good at it it takes me 30 mins but you have to rebleed the system:)
how old is the water pump as some are known to rot away or the pump becomes lose on the shaft
but from what your saying it sounds like it could be thermostat but check the easy bits first
just noticed your down ramsgate way give DUSY MGF a shout
he might be able to help
