  • 2
I'm after some bits 13 years 3 weeks ago #23688
  • cjj's Avatar Topic Author
Well, Deepblue failed her MOT today.
She failed on emmissions (again).
Soooo. I am going to treat her to a new Cat and and new Lambda sensor.
I can get the Type approved (must be Type approved) Cat for £122.40 and the Lambda sensor (Bosch) for £56.34 from Erocarparts.
I found this sensor on e-bay http://cgi.ebay.co.uk/MG-TF-ZR-MGF-1-4-1-6-1-8-95-On-Pre-Cat-Lambda-Sensor-/180653980732?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2a0fd0fc3c but for the price difference I might just go with the Bosch one.
Any one tried these sensors or have any contacts for cheaper parts?
I'm not doing well at the moment, 3 cars MOT'd in the last couple of months and they have all failed. Even the Focus ST which was it's first MOT.
So, after shelling out £253 on the van to get it through it's MOT last week, I'm looking at saving a few pennies, but not at the expense of new parts, if you know what I mean. :)
Last edit: Post by cjj.
Re: I'm after some bits 13 years 3 weeks ago #23692
the ebay listing has been removed Clive.
I bought a pattern sensor off ebay, it was pants, so finished up with an oem one, I'd stick with the Bosch one.
Have you and Broon swapped luck
Pete Vickerstaff
Re: I'm after some bits 13 years 3 weeks ago #23694
Have changed the link.
Have I got Broons luck? I don't think so. It fails every year but needs an Italian tune up just before the test to pass.
Re: I'm after some bits 13 years 3 weeks ago #23696
This was last years. It was the second attempt after taking the car for a long spin. It failed on the first attempt.
This was today. No chance to take it for a spin.
Re: I'm after some bits 13 years 3 weeks ago #23704
It seems that they never bother to take the oil temperature, even when you've got an oil temp gauge. Incompetent gits!
My mate, who does MOTs, showed me the oil temp sensor that MOT testers have to have. It fits down the dipstick tube!
So why don't they use it? Too lazy, that's why!
Re: I'm after some bits 13 years 3 weeks ago #23706
Yep.
I was just commenting to Anne about the "engine oil temp sensor disabled" bit at the top of the sheet. It seems that they think water temp is the reading to go by.
Re: I'm after some bits 13 years 3 weeks ago #23708
I think it's time for people to start insisting they use the oil temp sensor, esp. when you get a fail such as has happened to you.:shrug:
Re: I'm after some bits 13 years 3 weeks ago #23713
I agree, but the last thing you want to do is upset the tester/tell him his job before he even starts. ;)
Re: I'm after some bits 13 years 3 weeks ago #23717
Might be worth asking if they fail it on emissions without.
Re: I'm after some bits 13 years 3 weeks ago #23718
I have a cunning plan.
I am still going to get the bits, but I am going to phone another local kwikfit and ask if they will do a free emissions test. If they do, I will get the engine red hot and see what the emissions are like, then I will have a word with the original about a free retest. :)
I am interested in whether it is their bad testing or whether I do have a problem.
Re: I'm after some bits 13 years 3 weeks ago #23723
Meg has had the same problem for the last 3 MOTs - if I take her for a long run JUST BEFORE the MOT and I manage to get in straight away then she seems OK (usually on the Retest!), BUT if she cools down a bit or I haven't taken her for a blast she fails dismally.....
This time the MOT guy (who chatted to me about Rover V8 engines a lot as soon as he found out I had a Range Rover too) revved the living daylights out of her for ages to get her nice and hot and she passed (Retest day of course!).... she had a new CAT and a Lambda sensor too 3 years ago. (which weren't needed as that first fail turned out to be the little vacuum hose that passes by the oil filler bracket - it had rubbed a hole in it! GRRR).
Last edit: Post by adamelphick.
Re: I'm after some bits 13 years 3 weeks ago #23749
I'm going on Friday morning to have the emissions tested at another station, after a long blast. ;)
  • 2
Time to create page: 0.110 seconds
