I am restoring a 1998 VVC and now have it running. During the refurb I disconnected the ABS unit and now have the light on. I have checked all the sensors and wiring and all are ok. There are no error codes. Can I use the pscan to reset this? If so what is the process?
Connect pscan
Select ABS
Select 5.0
Read any error codes.
Erase the codes.
Drive the car and see what happens.
If the light comes back on then read the codes again.
Report back here.
Check the fuses under the dash...had my TF have the ABS light on recently, Pscan didn't pick up the fault, turned out the fuse was heavily corroded, as were a few other in the fuse box
