Hi everyone, I have a 2.0 T-series in my discovery. The ecu is a 1.6.
When I was fiddling the other day I noticed the idle set speed on pscan.eu live data was at 0, so I went into the tuning feature and adjusted the idle set speed to the highest setting of +200rpm. The engine seemed to run smoother and the idle set speed in the live data went up to about 198rpm.
So couple of questions.
1. Is it possible to tune the idle speed to 850rpm through pscan?
2. Is it normal for the idle set speed to be 0rpm?
3. Should I try to change it or just leave it as is?
Thanks in advance
Rob.
