Dead battery following alarm/electrical oddities
Replied by sludge on topic Dead battery following alarm/electrical oddities
Posted 1 year 8 months ago #208979I know it did, and I'd already checked in there yesterday and not seen anything that would cause concern. I will certainly have it all out again though to confirm once I know for sure if my battery is ok or notThe boot hinge loom has already been highlighted. You need to open this up and check for broken wires. This happens to virtually every one of our cars due to bad design. Broken wires in there can cause a plethora of strange electrical issues!🤔
Replied by Airportable on topic Dead battery following alarm/electrical oddities
Posted 1 year 8 months ago #208980The old fashion charger was grunt from the moment it was connected, modern electronic devices tend to pussyfoot around their job.
They won’t, for instance, take a depleted battery & pump it up. Take my big electronicless charger, it will happily dump an almost limitless amount of current & it sounds like I’m trying to restart the heart of triceratops from a distance.
To spoof some of the more recent offerings into realising that they have got a job of work to do, is to connect a second reasonably healthy battery in parallel for a few moments before it’s safe to allow your charger out on its own.
“Not a lot of people know that”.
Replied by Notanumber on topic Dead battery following alarm/electrical oddities
Posted 1 year 8 months ago #208981You mentioned you had got/ were going to get a multimeter. What is the voltage reading across the battery at present ? This would quickly confirm why the load tester could not show a reading.
Posted 1 year 8 months ago #208984I'm definitely going to try this once I have the second battery available to me later.+1 For Airportable's advice. Put a pair of jump leads between yours and a 2nd battery. Then attach the battery charger and leave it like that for an hour or ideally several. Then take one of the jump leads off and leave the charger working on just your battery alone. Check that the charger is now applying a charge and if so now leave it to charge for several hours.
As for the multimeter, I misplaced mine some time ago so waiting for the new one to arrive from Amazon at some point today. Annoyingly they got sent as separate deliveries. Once it comes, I intend to confirm the actual voltage on the battery currently.
Posted 1 year 8 months ago #208987I put it back on the charger which as had done so far, immediately said it was full and when I put the tester back on it was at 10.1V, 10.0V, 9.9V and so on. So something is happening there that doesn't make sense, either the battery can't hold a full charge or the charger is crap like others have eluded to.
More importantly for this update though, and the reason I feel like a moron. So many mentioned checking the boot wiring loom, and I had looked - AT THE WRONG ONE. I just opened up the actual one on the hinge that you all so kindly pushed me to and it like a horror movie in there, see attached image. Of the seven wires I can count, 4 are cleanly disconnected with the others hanging on for dear life. I'm surprised it took this long for issues to arise. As soon as I finish work I'm gonna head to B&Q and grab a bunch of smaller gauge wire, as I only have big mains power style stuff, and go to work repairing them all and extended them too as others have suggested to ease the pressure on them when opening and closing the boot lid.
Replied by TA22GT on topic Dead battery following alarm/electrical oddities
Posted 1 year 8 months ago #208988I am learning so much about these cars since I joined this Forum.
When you have sorted out that wiring check with the multimeter what the alternator is putting to the battery.
Posted 1 year 8 months ago #208989There will be few contributors who regularly post on here whose job it is to repair cars in general & these in particular.
You have therefore to address the question, “how did they know that?”
They started by asking questions which they thought moronic, then all of a sudden they find out that the same question has been asked any number of times. Because you are hearing the same sort of question with such regularity & seen those constructive contributions from contributors you will eventually be able to advise on the answers even though, in some cases you haven’t experienced the problem.
You keep asking & the chaps on here, for sadly it is chaps, will endeavour to help.
Replied by Cobber on topic Dead battery following alarm/electrical oddities
Posted 1 year 8 months ago #208996Mind you, up in Oxford Street Sydney there are plenty of blokes that do chaps.....but that's another matter entirely!
Posted 1 year 8 months ago #208999Well done for uncovering the boot hinge wiring problems. Unless you have already been to buy the cable I would suggest you order a metre of automotive wire in each required colour rather than general wire from a general DIY store. Wire made for automotive use is a bit more flexible which is quite important for the hinge area which is subject to vibration and movement. The insulation layer is thinner but more durable than ordinary knock about wire. It's also best to match the existing colours. Joint are best soldered and covered with heat shrink tubing
Posted 1 year 8 months ago #209000“You keep asking & the blokes on here, for sadly it is blokes, will endeavour to help”.
Is that better Cobb’s? Maybe we might encourage the ladies (blokeses) to rejoin.
We try to be inclusive.
Posted 1 year 8 months ago #209002"Keep calm, relax, focus on the problem & PULL THE BLOODY TRIGGER"
Posted 1 year 8 months ago #209003To satisfy those grammarians amongst us, we would need to ascertain the mean age of the hypothetical female contributor, (spanner jockey/ jockette/jockess)
Once verified we would have to consult the good bergers of the OED to adjudicate.
