Dead battery following alarm/electrical oddities
Replied by sludge on topic Dead battery following alarm/electrical oddities
Posted 1 year 8 months ago #208964
I won't single out any messages to thank, but I really appreciate all of your advice and guidance. I've got a battery load tester coming tomorrow (today now I guess) as I didn't already have one, and a new multi-meter as I've misplaced that as well 🙄
Just to touch on a few things that were mentioned/suggested, in regards to door switches and lights etc, I was able to rule those out on the first day, when I still had power. By simply latching them I could see the interior lights go off, as well as the boot light going off so if the battery is genuinely dead (which I don't think it is) then it won't have been because of a light draining the battery.
Similarly, when I first tried to use jump leads from another working car, I still had zero ignition lights. It was as if the key just wasn't doing anything. I'm still optimistic that it's going to be something relatively easy to resolve, but I'm also expecting it to be a problem that plagues this car forever, which would suck as I intend to daily it.
Edit: some talk about earth bolts, this is something I'm wanting to follow further, I just need to find a guide of all the known earth points on the MG TF.
Last Edit:1 year 8 months ago by sludge
Last edit: 1 year 8 months ago by sludge.
Replied by bluebae on topic Dead battery following alarm/electrical oddities
Posted 1 year 8 months ago #208965
Good call on getting the load tester, should help narrow things down.
by bluebae
Replied by Roverlike on topic Dead battery following alarm/electrical oddities
Posted 1 year 8 months ago #208968
Maybe this thread could help you:  https://www.the-t-bar.com/forum/roverlike-s-guides/97850-mg-f-tf-earth-points-locations-guide
The following user(s) said Thank You: sludge
Posted 1 year 8 months ago #208974
You are a star! I had already been using your fuse/relay guide for help to find all possible blown fuses, I should've guessed you'd made an earth guide as well.
by sludge
Posted 1 year 8 months ago #208975
Take a look, maybe something else could help you as well, like boot hinge guide:  https://www.the-t-bar.com/forum/roverlike-s-guides
Replied by David Aiketgate on topic Dead battery following alarm/electrical oddities
Posted 1 year 8 months ago #208976
The boot hinge loom has already been highlighted. You need to open this up and check for broken wires. This happens to virtually every one of our cars due to bad design. Broken wires in there can cause a plethora of strange electrical issues!🤔
Last Edit:1 year 8 months ago by David Aiketgate
Last edit: 1 year 8 months ago by David Aiketgate.
Posted 1 year 8 months ago #208977
Another quick update, the battery tester came quite early this morning (gotta love Amazon) and immediately I wanted to see what was going on. Wanted to be as concise as possible, so pulled the battery again and put the tester on. Weirdly enough, the screen just flickered on and off. I reseated the clamps and got it into a position where the screen stayed on and it could 'start up' I suppose you'd call it.
Immediately though, "Er3" which according to the book means "This symbol indicates the tester is abnormal or the battery capacity is beyond the test range." Now, that last part is what threw me off as it's a tester for 12V lead acid batteries, and it has a test range of 5-20V so that would tell me that it's likely below the 5V threshold. But then it makes me curious as to how my charger again immediately told me the battery is fully charged.
I'm waiting for a friend to come over and I'll be using the charger and the tester on a known working battery, just to rule out a failure with them (very unlikely, but you have no idea h ow unlucky I am). Assuming they work, I will likely have to get a new battery but that scares me as there were no signs of degradation on the current battery. It's an Exide EB602 that came with the car but doesn't look too old.
Considering I was getting the strange door open beep on Saturday evening after an uneventful 2 hour, 77 mile drive, I don't want to spend £80/90 on a new battery only to have a fault kill it within a day again.
by sludge
Replied by TA22GT on topic Dead battery following alarm/electrical oddities
Posted 1 year 8 months ago #208978
I'm new to MG Rover so I can't offer too much but with the advice of others, you trying a known battery I think you will home in on the fault.
If your battery is good it's time to look at the boot wiring loom I think!
Good luck!
Posted 1 year 8 months ago #208979
I know it did, and I'd already checked in there yesterday and not seen anything that would cause concern. I will certainly have it all out again though to confirm once I know for sure if my battery is ok or not :)
by sludge
Replied by Airportable on topic Dead battery following alarm/electrical oddities
Posted 1 year 8 months ago #208980
One point about battery chargers; they are not all equal.
The old fashion charger was grunt from the moment it was connected, modern electronic devices tend to pussyfoot around their job.
They won’t, for instance, take a depleted battery & pump it up. Take my big electronicless charger, it will happily dump an almost limitless amount of current & it sounds like I’m trying to restart the heart of triceratops from a distance.
To spoof some of the more recent offerings into realising that they have got a job of work to do, is to connect a second reasonably healthy battery in parallel for a few moments before it’s safe to allow your charger out on its own.
“Not a lot of people know that”.
Replied by Notanumber on topic Dead battery following alarm/electrical oddities
Posted 1 year 8 months ago #208981
+1 For Airportable's advice. Put a pair of jump leads between yours and a 2nd battery. Then attach the battery charger and leave it like that for an hour or ideally several. Then take one of the jump leads off and leave the charger working on just your battery alone. Check that the charger is now applying a charge and if so now leave it to charge for several hours.
You mentioned you had got/ were going to get a multimeter. What is the voltage reading across the battery at present ? This would quickly confirm why the load tester could not show a reading.
Posted 1 year 8 months ago #208984
I'm definitely going to try this once I have the second battery available to me later.
As for the multimeter, I misplaced mine some time ago so waiting for the new one to arrive from Amazon at some point today. Annoyingly they got sent as separate deliveries. Once it comes, I intend to confirm the actual voltage on the battery currently.
by sludge
