No oil pressure light? 2 weeks 18 hours ago #201289
Hi there, I have just bought a 2004 TF, 75K, FSH. I bought privately online, and therefore unseen as seller was many miles away. Yes, risky I know. All seems fine except when the ignition is turned on, no oil pressure light. I bought the car at a pretty reasonable price so don’t mind doing a bit of work if required. Many thanks in advance for your sage like advice!
No oil pressure light? 2 weeks 5 hours ago #201292
Is the wire plugged onto the sender switch? Check the light bulb in the instrument cluster.
The following user(s) said Thank You: Jim479
No oil pressure light? 2 weeks 5 hours ago #201295
:welcome2:
No oil pressure light? 1 week 5 days ago #201319
If you earth the wire (ignition on) from the pressure sensor the oil light should come on, if it does then the sensor is duff, if it doesn't then it's the bulb (easy) or a wiring prob (!!!!). There are 2 sensors on the oil filter housing make sure you earth the correct one, the picture should help. Peter
No oil pressure light? 1 week 3 days ago #201338
Did you get this resolved, it is always good for us to know that a problem is sorted & what the root causes was. Information like this helps other members.
No oil pressure light? 3 days 16 hours ago #201417
Thanks all, turned out to be a faulty pressure switch, disaster averted. Thanks to all.
The following user(s) said Thank You: David Aiketgate, Airportable
Time to create page: 0.102 seconds
© 2023 The-T-Bar.com All Rights Reserved. Hosted By SEBS IT
