  • 2
wheels 6 years 5 months ago #181864
do the mgf wheels fit the mgtf thanks:-?
wheels 6 years 5 months ago #181867
In a word, Yes
but
not all MGF or TF wheels will clear all sizes of brake.
wheels 6 years 5 months ago #181868
I have the normal brakes, not the uprated. 15inch,
wheels 6 years 5 months ago #181874
With normal brakes on you can fit any type of F or TF wheels.
16" Square spokes are my favourite but they wont fit over ap calipers :( without a conversion of some kind.
Last edit: Post by Bob.
wheels 6 years 5 months ago #181876
Thanks but what are AP calipers????
wheels 6 years 5 months ago #181881
They are multi piston callipers to apply more/even pressure onto bigger discs
wheels 6 years 5 months ago #181882
The ap calipers look like this.
Some years back I messed around swapping wheels around on my escort and the larger wheels on land rovers...I found it changed the reading on the speedo ....in my case it was 10mph out...not sure what to expect if you were to go from 15 inch to 16 inch rims...I'll leave that for another member to answer.
wheels 6 years 5 months ago #181883
Changing from 15” to 16” wheels will mean using a lower profile - 40 or 45 depending on tyre width. As long as you do check on a tyre size calculator and the %age change is less than 2.5% then the speedo will be correct. If ou use standard MG wheels and tyres then there is no problem.
wheels 6 years 5 months ago #181884
This is my 1.8i on 16 inch square spokes which I fitted a few years ago having had the standard 15 inch round spokes (which also looked OK). No speedo issues as the profile is lower. I have the standard brake set-up which is fine provided your discs, calipers & pads are in good condition.
Richard
wheels 6 years 5 months ago #181886
nice car, thank you.
wheels 6 years 5 months ago #181887
I like that car...it looks fantastic..and I like the square spoke wheels...
Re:RE: wheels 6 years 5 months ago #181894
As long as you use a lower profile tyre 40 for 16" then the overall diameter wil be the same as a 15" with a 45 profile.
Sent from my MediaPad T1 8.0 Pro using Tapatalk
  • 2
Time to create page: 0.128 seconds
