hi guys, well my tf 1.8 2002 just failed its mot, (1) the revs are sitting at 1000 it should be 800 , so took off the iac got some carb cleaner and gave it a good clean and the throttle body as well popped it back in and its still sitting at 1000 so cleaned up a spare:bat: swopped it over and still the revs are sitting at 1000, so with the engine running i removed the pipe between the iac and the throttle body expecting it to rev up or drop nah revs still stayed at a 1000 do you think i need to reset or do you think its something else ?
(2) problem my speedo has according to the garage stopped working and the petrol gauge seems to be stuck on 1/2 a tank, whipped the binnicle off to see if one of the connections has come loose also checked to make sure the connection at the side of the grearbox was ok it was , so do you have any ideas
