Hi, as above, you will need a reader to find out the code. You can purchase a really basic one off of e bay. This will let you see what the issue is. Sometimes the light will come on, and the problem maybe insignificant i.e., it may just be a Missfire on one of the cylinders. With this equipment, you can turn off the light and ignore the issue if it is nothing of any significance. It will be a lot cheaper than taking it to a garage, or, you can then advise the garage that the car has a particular issue and you will at least have a heads up.
Cheers
