Im missing the manifold heat shield on my mk1 mgf . Although ive had my car for nearly 2 years and its been missing since ive had it i would like to replace it as i want to protect the coolant pipes and alternator from getting heat damaged . Anyone know where i could source a heat shield from ??
Cheers for that . Can anyone confirm the mk 1 heat shield is actually 2 seperate heat shields ? 1 for alternator side and the other for coolant pipe side
Hi,
Go on the rimmer brothers website, and it will show you an exploded view of the heat shields, bolts etc with the part numbers.
From this view, you can determine which parts you require.
Yes but one from a mk2/TF will fit.
Home to black Alfa Romeo 159 3.2 V6 Q4 ,green MGF VVC andred MG Maestro T16.
The following user(s) said Thank You: bluesunshine
Rimmer lists the heat shield on the alternator side, YLP100570, no longer available, nor is the bracket. The heat shield on the coolant pipes side, WEB101230, is available, as well as the required brackets, quite cheap too.
Mark
95 MGF
