Hold fire - DO NOT BUY a generic clutch listed for a 1.6 K series, it will not fit a MG TF 1.6, you need 1 for a 1.8 TF.
Why you may ask?
The 1.6 TF uses a PG1 gearbox and is the only MGR to do so, all other 1.6's use IP5 or R65 boxes.
This is because it was easier to modify the gearsets etc. than modify the gear change to suit the other box.
The 1.8 uses the URF000122 clutch kit.Ok.The URF000170 kit is for the MGZR 1.6 with the R65 gearbox.
The I.6 F and TF has the PG1 gearbox and requires the URF0000160 Clutch kit.
