I've been considering this as one of my front lower suspension arms is shot, the other is like new but hasn't been touched in 6 years of my ownership. Also I am fed up with the suspension going down and refurbished spheres will come in at £400. On the other hand the hydragas is better for cruising than the firmer TF.
At the front you need to disconnect the steering column, brake calipers which can be tied up to save bleeding the brakes. Depressurize the hydragas and disconnect the hoses. Drop the bumper and drop the subframe.
The back is more complex as the engine needs to come out so all pipes, hoses, wiring etc needs to be disconnected, IIRC the clutch slave cylinder can be tied out of the way, same with the brake calipers but the handbrake will need disconnecting.
