In any engine as the oil gets hot the oil viscosity thins and the pressure reduces.Hi all,
I bought my MG TF 1.8 around 3 weeks ago, and unfortunately I already have a concerning problem with it...
I don't have a trusted mechanic (the one I had closed down...), so before I take the car to a new one I'd like to have your opinion on what might be going on.
The problem
When the engine is hot (oil temp higher than 90°), the oil pressure light starts flickering when the engine is idle. If I rev it even slightly, the light goes away. If I turn off the engine for a few minutes, allowing for the oil to cool down, the light stays off. No weird noises when turning on the engine and no other signs of something not working properly.
Some background
Right after I got the car I went for a very long drive (obviously!) and had no problems at all. The next day, with cold engine, I checked the oil level and noticed that is was very low, below the Min mark. I then topped it up with some 10w40 oil I had at home and the oil level now sits between the Min and Max markers.
I started having the oil pressure light problem only after I topped up the oil. As a side note, something bad must have happened to my oil dipstick in the past, since it looks "clamped" around the Max marker and the marker itself is not clearly visible.
Possibile problems
I have some ideas on what might be wrong:
1) I might have topped up with a different oil from what was already in the car, even though I used the oil specified in the user's manual.
2) I might have overfilled and when the oil gets hotter and expands it messes up with the oil pressure sensor. The oil level looks fine on the dipstick though.
3) The oil pressure sensor might have some problem and needs to be replaced.
4) The oil pump is slowly dying. In that case though, I should get the oil pressure light on even with a cold engine.
Any ideas of what is going on here?
Thanks!
