Help me!!!! Problem Suplex kit x mgf!!!! 8 years 2 months ago #165319
Hi, J'm a italian user and sorry for my english.
After assembling the whole thing, and you have followed the letter of the manual, you adjust the height from the ground l 'car as suplex specifications, is impossible to drive, at each hole in asphalt black cylindrical boxes which house the bounce causing springs of noises between boxes and springs. Perhaps because the suspensions in my opinion too soft does not work properly.
I thought I had made the correct choice in place to Hydragas, and now find me a mgf unusable, and over 1000 Euros thrown to the wind.
This email is a request for help, kindly await the resolution to the problem.
Thank you
Inviato dal mio Lenovo B6000-F utilizzando Tapatalk
Help me!!!! Problem Suplex kit x mgf!!!! 8 years 2 months ago #165321
Hi and welcome to the forum
Sorry to read about your problem.
There are a couple of people who know about the Suplex suspension who may be able to help.
James
Re:RE: Help me!!!! Problem Suplex kit x mgf!!!! 8 years 2 months ago #165324
James
I can contact them?
Help me!!!! Problem Suplex kit x mgf!!!! 8 years 2 months ago #165325
They may reply when online. :)
Click here for the Italia MG TF Passion club. :hugs:
:welcome:
www.tfpassion.it/
This email address is being protected from spambots. You need JavaScript enabled to view it.
Direct link to their live forum.
Help me!!!! Problem Suplex kit x mgf!!!! 8 years 2 months ago #165326
Hello :welcome: to the forum, sorry you have a problem. I hope you soon fix it.
Regards.
Help me!!!! Problem Suplex kit x mgf!!!! 8 years 2 months ago #165330
Thank you
I don’t think there is a solution to find the correct operation of the Suplex suspension kit without compromise that can be retro fitted to the MGF, it may suit other vehicles but if you look across the forums it is fraught with people having major issues with this kit when fitted to the MGF.
As the years roll by there won’t many MGF’s left on hydro gas suspension where the nitrogen accumulator bladder is correctly charged with gas, you can pump up the fluid to maintain the correct ride height but as the nitrogen is slowly absorbed out of the accumulator bladders the ride will harden up and the only suspension you will have is by the fluid displacement from one sphere to the other giving a pretty rough ride. Until someone comes up with a re-manufacturing process for replacing and re-charging the accumulator bladder or manufacture of new spheres you would be best putting up with the original system.
If I was looking to keep hold of an MGF as a classic car and had doubts over the nitrogen content in the spheres I would go for TF subfames (coilovers). I know it’s a big task but when it’s done you know it will work correctly for the rest of life of the car.
While there is still a glut of TF’s around for breaking and plenty of cheep second hand TF subframes; I think that would be the way to go. It’s a lot of work but with the exception of drilling the 2 holes in the inner wings for the strut tower tops; the rest is just a swap and would make a great winter project as you could refurb/paint the new frames ready to go over the summer and then take the car off the road for a month in winter to do the swap.
If I had paid 1,000 Euros for a kit that won’t work correctly and a lot of time and effort to fit which is now making the car un-drivable I would want my money back from the seller as a “sale of goods not fit for purpose” If you pay that much money for the kit it should go straight on the car and work, and you shouldn’t have to go back to Suplex who will keep fobbing you off with telling you to keep making adjustments.
I am sorry it’s such a negative response and not very helpful to your situation, but I hope you can find the best solution.
Brian.
Help me!!!! Problem Suplex kit x mgf!!!! 8 years 2 months ago #165341
:welcome2:
Unfortunately, this is a problem that appears many times with the Suplex kit. :bang:
In my opinion the supplied front springs are too soft. The spring seat is pushed into the canister and makes clonking noises by hitting the canister wall.
Have you contacted Suplex? That must be your first call. It's up to them to solve the problem. They are well aware of this clonking issue, I alerted them to it almost 4 years ago! :rant:
I ended up putting rear canisters on the front but this gives a high ride height. The height issue is solvable, but I won't explain on open forum. If you end up with rear canisters on the front, PM me.
Incidentally the Monroe dampers that they insist you buy are worse than useless, unless they have drastically redesigned them...
Re:Help me!!!! Problem Suplex kit x mgf!!!! 8 years 2 months ago #165354
Thanks to all x the information, I contacted the seller and he told me that the front replaces defect canister, but now I have to take back across the front, are at the limit of endurance !!
Re:Help me!!!! Problem Suplex kit x mgf!!!! 8 years 2 months ago #165887
I've been contacted by another member who has been let down by the Suplex conversion, literally.
Despite full adjustment, he is struggling with a ride height around 325mm.This is not much more than the car running around on the bump stops!
Despite adding more spacers on the pins, the height doesn't increase because the springs just compress! :bang:
Time to create page: 0.112 seconds
