Hi
I have a '96 MGF 1,8i. It is running perfect, but i have a problem at MOT where it did'nt pass because the co was a little high (1,5) and the lambda a little low(0,96) assuming rich mixture.
AS Said the engine is running perfect and there are no deposits on the plugs. I have made a diagnostic with a PSCAN, and there was no FAULT codes. The live data also looks very fine, but 3 numbers may be problematic:
The mixture is 14,5:1 . Is this to high and is it possible to adjunkt
The air intakte temp is 59 deg. Is this to High and if is is then why.
The stepper motor reads 16. Is this to low and does it matter
Sort my english (i am from Denmark)
