Whenever i have lights on both my headlamps mist up seems to have become worse over the winter, Any ideas on a cure?
Forgot to add that it's a tf model and when the lights have been off for a few hours the misting inside disapears.
I believe there should be some little plastic cups pushed onto the back of the headlamp, which contain little sponges. If you pull these off and then dry out the lamps, then dry the sponges and/or replace them. That should help.I'm only speaking from memory as I have an F so may be talking rubbish.
going to take a look around the lamps tommorow, armed with a hairdryer and some new sponges, if i find out where they fit!!!!!, David thanks for the guidance will keep you in the loop as to what happens.
