All K-series bottom ends were standardised to 160 spec by the time Euro2 engines were released - the only different one being the 1.8T, and I gather that there had been plans to standardize on that bottom end, but the company went belly up before that could happen.
Therefore I think that you probably have the best bottom end already - and although marginal at 100bhp per litre, should be fine. The next upgrade step would be forged pistons and rods; the crank is usually good for even higher power and rpm than you've currently got (probably around 220bhp, 8500rpm cut off).
