My late 2004 model MGTF had a distinct wobble with the NSR wheel. Anyway, the whole thing was duly dismantled for inspection. - I love the way the book says "remove the flange nut". It took some serious "humouring" to get it undone
It was immediately apparent that the newness had gone out of the wheel bearing and the bottom bush on the shocker was a shocker!!! No problem these can easily be replaced. However, when I checked the other bushes - particularly the upper trailing arm, these seemed to me at least to have a lot of movement. Several 'phone calls later I discover that these parts are no longer available A main Rover supplier even told me he had never sold a trailing arm ever and had never had one in stock Ok. Try different tack and ask about polybush kit. Told that no that doesn't contain the trailing arm bush.
Sooo.... Just how much "play" is acceptable in these bushes I did try to upload some pics of the relevant parts but, the server didn't want to know. Perhaps it doesn't do bushes either??
Normally, I'd replace these parts without a second thought but as they're not available I'm going to have to put it back together with only a new bearing and shocker. Ok so, by the time it's all buttoned up the whole assembly is held from six different points and there is likely to be little or no movement. But just how much play should be in these bushes? I did ask my local MOT tester and he said it's a subjective assessment based on experience. Short of taking another TF apart - ( I'm sure you'd all be happy for me to do that on your TF if I ask nicely ).
Hi David. Yes that's the beast. Rimmers list it as Part No.: RGD000920. They currently don't have it - or replacement bushes. Minor point but what am I doing wrong as I can't seem to upload piccies.
If you struggle for a new one i have this one having covered only twenty thousand miles.
It is not uncommon to have play in this bush it is quite a soft bush that generally moves 10mm from centre.
Hi thanks for the response and very kind offer. You've actually answered my original question. I was concerned about the amount of movement in these bushes. But mine is about 10mm also. Have now had chance to check another TF - thanks Tony - and that was exactly the same. So, have now put the original back. There is no play at all when it's all buttoned up and my local MOT guy gave it the thumbs up! I was just surprised at how "soft" the bushes are. Cheers.
