I fitted a battery isolator a while back, this type requires no modification or alteration to any of the wiring, all you need to fit it is a 10mm spanner.
It's safer to always to switch off the negative as it makes no difference if something touches the terminal and you don't need to insulate anything.
Takes less than 5 minutes to fit.
Brian.
