Thanks guys
the gearbox was from a 2nd hand dealer with 3 months warranty (its outside of that now - just)
the issue I am 100% certain is electrical...
the gearbox only gets Esso EZL 799 cvt fluid (either from BMW or opie oils), the level is exactly correct when warm at idle in neutral on flat ground...
the error codes are not persistant, they do not light up the engine management light, they are just shown as temp error codes when I am viewing the live data on my wifi ODBII dongle via iPhone when driving...
the gearbox warning light doesn't stay on either... the engine bay overheat light does stay on, but even if car is cold and just turned on on a frosty morning, so its not that the engine bay is overheating... no relays, or fuses have failed (all checked)
the engine bay fan kicks in when it does get hot and stays on when car is locked and parked until temp comes down (as it should)
engine oil temp is 90-105C, coolant temp is always 87-88C regardless...
engine fault codes have been cleared...
I have not got access to a T4 for gearbox testing...
if someone offered me £1000-1500 for the car right now I would take it and be rid... I need something reliable ASAP.
I don't have time to faff with this stupid car any more.
its had a brand new engine
fully ported and polished head
fully blueprinted and balanced
all standard cams, valves etc (but polished and ported)
all new gaskets & seals
bespoke water pump
87C PRRT installed
adapter fitted for oil to water cooler (TF160 one) (not fitted due to lack of funds from fault finding!) - I have the oil to water cooler its self ready to go
its got 160 lowering knuckles on hydragas suspension with adjustable Gaz shocks...
R1R's on rear, and AD38 advans on front
drilled and vented disks & nearly new pads
just needs a little tidy up, centre console had a few holes in from last owner, have a replacement that's better to make interior perfect.
(except the heater controls snapped on the fan speed adjust so needs a new adjuster knob)
TT Mk5 exhaust
Inline induction filter with ported and smoothed throttle body...
anyone want a project? probably an easy fix if you know what you are doing with electrics....
all the threads I have seen with CVT issues online have thrown Cam position sensor as the error (even though its not)... so that was a waste of £95... engine had all new sensors when it was built in September. only 1500-1800 odd miles on new engine which is absolutely lovely...
or anyone know of any specialists I could take this to? I am on surrey/hants border...
