Hey all. The wife started the TF this morning and the engine warning light came on. This only happens when temperatures drop below freezing, which they have started to do recently. The last time this happened we made an unscheduled stop at a garage and the mechanic plugged in his diagnostic machine, reset it and told us to contact him if it did it again. He wasn't sure at the time if our particular TF, (2004, 115) had a sensor, (possibly Lambda) as apparently , some don't ,and whether that might be the problem.
Anyway, it's a solid, not flashing, light and apart from that the car drives fine......any thoughts.
If sensor. Is it an easy fix? No garage or axle stands at the moment though.
Cheers.
