From an MG TF 120 2005
Had the box out, sump pan off, new collector/filter, cooler and pipes off, cleaned re-assembled; bought 5 litres of oil, put in 4 litres, run up, took about an extra ½ litre and re checked when hot; total used 4.5 litres, half a litre spare.
Is it the original box? Maybe in other applications the dipstick tube could be a different length for filling access, is it the original cooler.
You need to measure the filler tube length from the casing and the length of the dipstick blade and find someone on the forum with the same model needs who can do the same so you can compare.
Brian.
