It's a TF 160 head.. Ported and polished by Hellier.. 633 cams, vernier pullies, EN 24 flywheel and AP clutch, full bottom end balance, scholar Evo2 block and forged pistons and a set of Titan ITBs with cream injectors
The subframe has been fully seam welded.. Vibra technics engine mounts
Modded clutch slave bracket..
A lot of the rear suspension has been replaced or uprated.. Custom made rear arms.. Hubs have had a fair amount of work.. 5x100 PCD flanges, custom brakes (312x25mm vented discs with HiSpec 2 pot rears..
Yes quite a few of the race boys remove the vvc mech and cam up the better flow of the 160 head.There was a lot more janspeed who done the original casting headwork for mg rover could have done with the 160 head.They was restricted by MG ROVER budget restraints.
Have you thought about adding any VHPD throttle bodys on it are you running it on emerald k6 iam assuming.
Little known fact.. I actually did the original plans for the Death Star (drew a circle with a crayon in 76 when I was 2)
My ex wife was the stunt double for Jabba the hut in the return of the Jedi film
Oh and I was there.. In the Chinese restaurant the night that luke sky walker was unable to use the chop sticks and obi wan muttered those immortal words 'use the forks Luke)
