Road tax is the same for 135 and 160: £220 for year/ £121 for 6 months.
The 1.6 is 200 quid for year/110 for 6 months.
The Internet. A thing of wonder.
Hi The V V C TF also gets bigger brakes [4 pot ] on the front and it cones standard with half leather seats and the wheels are different and the F V V C had electronic steering [ all the TFs have this ]
The main difference is the VVC mechanism itself. The 135 is an mpi like the F mpi(118bhp), both have the standard double camshaft single / cam belt set up.
The F VVC 143bhp), Trophy 160(158bhp) and TF 160(158bhp) all have the variable valve timing. Two piece inlet camshaft with extra mechanism, a belt at each end of the head.
So the easy way to spot them is the extra mechs on the head. The VVC also have a higher rev limit 7250 instead of 6800.
Only some very early 1995 mgfs didnt have epas ,very rare to come across without epas terrible to steer on lock ,nice at speed and high speed corners after that vvcs and mpis all had them
Actually it's not John. See my earlier post.
Pre 2004 135TFs have a higher vehicle excise duty than later models. ... £245 per annum IIRC.
This is because the ECU map was adjusted around late 2003 to give more economic performance over the rev range, sacrificing a miniscule amount of torque to achieve the lower emissions.
I know because I had a pre 2004TF. I had it remapped with the post 2004 spec and petitioned the DVLA about lower tax .... can you guess what their reply was ... ?
